It is currently Sat Jul 05, 2025 11:25 am
PostPosted: Tue May 22, 2018 12:57 pm
City: Escondido
Zip/Postal Code: 92029
My guitar buzzes/hisses/hums. A tele I made with a CC style pickup at the neck. When I touch the control knobs (brass) the humming goes away. I assumed some grounding issue. However I took the control panel off the back and touched the pot's housing. The humming did not go away.
Not having much experience with this stuff, I'm stumped. Touch the pot's shaft and the humming goes away. Touch the casing or ground wires, no effect. What would be the cure, doctors?
PostPosted: Tue May 22, 2018 3:21 pm
First name: Freeman
Last Name: Keller
Something doesn't make sense. A metal knob has a setscrew that fastens it tightly to the shaft of the pot. The shaft is grounded to the case of the pot which is your ground common point. The case of the pot is also grounded to the metal cavity cover. I guess it is possible that the shaft is floating but I've never seen that.
Common causes of buzzing include
- cold solder joints, particularly any ground wire and certainly the common ground point (usually the back of one of the pots)
- reversing the hot and ground on the jack (its easy to do). Will still work but usually hums badly
- lack of a string ground. Run a ground wire from your central ground point to the bridge, that will put your strings at ground potential.
- Cavities should be shielded and the shields connected to your common point.
- On some neck pickups there are three wires - hot, coil ground (which goes to the switch) and pickup case ground (which goes to the common point). I had a boutique pickup that had the wire colors reversed - it would hum like crazy when I grounded the case. Reversing the hot and coil ground fixed it.
PostPosted: Tue May 22, 2018 4:05 pm
City: Escondido
That is exactly my confusion. Touching the pot body with my finger didn’t seem to change anything, but touching the post quieted the hum. Isn’t the post and body connected?
Bad pot, possibly? Weird, weird, weird.
PostPosted: Tue May 22, 2018 4:14 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Volume or tone knob? I am wondering if there is a cold solder on one of the capacitors.
PostPosted: Tue May 22, 2018 6:59 pm
City: Escondido
I don’t know really what a cold solder is, and I can’t find imagine what the capacitor has to do with it, but....
I think you hit it on the head!!!
I was checking the wiring for the millionth time and I bent the capacitor out of the way. Ta da! Buzzing stopped. I figured it was coincidental, but I gather somehow a bad connection with the capacitor can induce a buzz. Because... Er.... What? And that connects to the post by...
Awe heck! I admit my king fu isn’t strong. I’m going to re-solder that capacitor and hope the problem is gone for good.
Thanks!
PostPosted: Tue May 22, 2018 9:08 pm
First name: Freeman
Last Name: Keller
A cold solder joint is one where the pieces being soldered (wire and pot case) weren't hot enough to get the solder to flow and evenly coat the surfaces. A good solder joint is shiny and bright, a cold joint is usually dull. Reheat it and flow a little more solder into the joint.
PostPosted: Wed May 23, 2018 12:03 pm
Last Name: Parchem
City: Seattle
State: Wa
I know very little about electric guitars but 35 years as an electrical engineer was good for something. The body is a better capacitor than it is a ground strap.
PostPosted: Wed May 23, 2018 8:11 pm
First name: David
Last Name: Schwab
City: Staten Island
Zip/Postal Code: 10201
The buzzing might have stopped because now the cap is shorting the high frequencies away
Do the pots have ground wires connecting them together, and to ground? Don’t rely on the control plate to make the connection.
I had this issue on one of my basses. Even though it was properly wired. I ran a second ground wire from the pots to the jack and that fixed it. Not sure why.
Also, this might be an issue with the grounds in your house where you have the amp plugged into. Are your strings grounded?
PostPosted: Fri Aug 10, 2018 6:29 pm
Look up star grounding for electric guitars, and ignore any suggestion it has to do with ground loops. By using a central ground point to which all components ground directly (and never via another component) you ensure the shortest path to ground which will prevent buzzes. If you also use shielding throughout the cavity and also ground this you should be buzz free, 60 cycle hum aside (this is magnetic rather than electrical interference). You’ll know you’ve done it right when touching the strings or controls doesn’t make an improvement on how much buzz you are getting.
Final note: it’s dreadful industry-wide practice to use the back of a pot as a central ground point, and also to solder the caps directly to a pot! This makes the casing part of the circuit which is asking for trouble. Use a washer a your central ground point and run a ground strap from each pot to this. The cap should also terminate here rather than on the back of a pot.
PostPosted: Wed Jun 12, 2019 2:23 am
First name: Monte
Last Name: McDonald
City: Santa Cruz
Zip/Postal Code: 95062
Reviving this old thread because I have the same issue.
Tele build with the 4 way switch.
Any position that involves the bridge pickup has a horrible buzz that goes away when touching the (metal) volume knob or tone knob. When on the neck pickup only, no buzz. Why would this only happen while the bridge pickup is in the mix?
Solder joints are all nice...but I did use the back of a pot as a ground location per the instructions I got. I will try the washer trick just in case. Will report back if that fixes it.
It's not my equipment as I get zero buzz on my other guitar. Just on this new one.
Any thoughts? Thanks for any input.
PostPosted: Wed Jun 12, 2019 3:45 pm
What pickup do you have in the neck?
PostPosted: Thu Jun 13, 2019 6:29 am
A couple of things to know and/or check.
It's a single coil pup and they are inherently noisy and this is why the humbucker was invented.
In our neck of the woods 50% of the structures, homes, buildings, etc. have poor grounds and single coil pups will bring this out.... bigly... Often a different cord or venue has different results.
Single coil noise can be reduced greatly at times when the pup is adjusted properly. If it's too far from the strings you have to crank the volume also cranking the noise. Adjust the height appropriately and the noise often can be reduced and at times greatly.
Don't know who wired this one up but much of the commercial, factory wiring that we see is very substandard with cold joints and other mistakes being in play.
Good luck.
